Dzisiaj jest 08 marca 2026, 07:48
Post: 07 lipca 2016, 23:15
Pojazd: Żuk A06
Witam,
Nie mówię poprawnie po polsku, czy można mówić po angielsku?
Assuming it is ok:
What kind of wheels/rims camee by default on FS Lublin 33 along with the Andoria 4C90?
I'd be interested to know whether they kept 6.50 R16 C from Żuk, switched to the exact diameter replacement but much larger 205/80 R16, or switched to something else thinner (R15 based, etc).
What is the choice FSC engineers actually made to accomodate 4C90 70hp and ETRTO tyres? Could that choice also be valid on 4 gears transmission Żuk?
Post: 08 lipca 2016, 01:31
Hello :)
As factory equipment (OEM):
For Żuk always: the rim 4,5 x E16 and tires 6,50 R16C
For Lublin 2,9t (gross weight): the rim 5.5JX15'' 5x139.7 with tire 195/65R15
For Lublin 3,5t (gross weight): the rim 6JX16'' 5x139.7 with tire 205/75R16C
The engine and gearbox type doesn't matter.
If you need more information feel free to ask :D I'm not sure ii it's exactly what you've been asked for ;)
P.S. Where are you from? What car do you have got?
Post: 08 lipca 2016, 19:49
Pojazd: Żuk A06
Thanks for the input, that was exactly what I was loooking for!
I'm currently actively seeking a Żuk to buy to make a small practical camper van out of it. For practicality, I'll go for the Andoria engine because I need the simple reliability of diesel engine (no ignition timing/etc concerns, no carburetor, etc) since I'll only use it during holidays and it'll be used from time to time by my father in law (that owned a Żuk something like twenty years ago before he got a Ford Transit) for his business.
I'm a bit concerned about the fact that 6,50 R16C are getting quite uncommon (only two references on most major website, expensive for what it is) and a bit puzzled since the replacement that would match diameter would be 205/80 R16 (165mm vs 205mm width!).
I noticed many people doing Złombol get these large Suzuki Vitara wheels, that seems a bit too much to me, I'd be more interested, if I feel a change of set of wheels is in order, to pick the logical FS Lublin 33 choice.
Aside from that, I'm from France, living in Paris (but born and grew up in Alsace - https://pl.wikipedia.org/wiki/Alzacja ). My wife is from Wrocław. We are happy owners of a 126p FL.
Post: 08 lipca 2016, 20:39
126p FL-c' est meilleur 126p:P)
orginelles 6.50R16c-voir des pneus nouvelles Sava et Hankook.
salut:)
Post: 25 lipca 2016, 19:54
Pojazd: Żuk A06
For the record, my Żuk is acquired now! An andoria A06.
Description here: https://zukowka.wordpress.com/
Next step : repaint, fixes, make a camper van out of it :-)
Post: 25 lipca 2016, 23:15
Good luck! :D
